RSVSR Why Pom Pom Picnic Is the Best Time to Stack Dice
Автор Rodrigo, марта 21, 2026, 11:28:34
Rodrigo
I've been saving my dice for Pom Pom Picnic, mostly because it's one of those short events where you can actually feel your progress move. If you're still chasing album pieces, it helps to know where to look for Monopoly Go Stickers and when to push your rolls. The event runs March 20 through March 23, and if you're steady about it, the milestones can snowball into a huge pile of dice, sticker packs, and a couple of those limited tokens people won't stop flexing.
Don't leave your multiplier on autopilot
A lot of players torch their whole stash by riding a high multiplier the entire time. I get it—it feels faster. But it's usually just waste. Most of your rolls land in that 6–8 range, so use that. When you're sitting roughly that distance from a Railroad, that's when you bump the multiplier up. When you're 10–12 away and the path looks empty, drop it back down and cruise. It's not glamorous, but it keeps you alive long enough to actually reach the chunky rewards.
Hunt the scoring tiles that chain into more points
For Pom Pom Picnic, you're basically playing around three tile types: Railroads, Chance, and Community Chest. Railroads do the heavy lifting because shutdowns and heists feed straight into event scoring. Chance is sneakier but sometimes better, since it can fling you forward to a Railroad or hand you a card that changes the whole lap. Community Chest isn't always exciting, but it adds up when you're rolling in volume, and it can keep your rhythm going when the board feels stingy.
Bank dice, then spend them in one focused run
If you trickle your dice the moment they regenerate, you'll hit a couple milestones and stall out. What works better is waiting until you've got a decent stack, then playing in one intentional session. Early rewards tend to kick back dice and boosts, and that feedback loop is what carries you. Also, don't force it when your token's in a dead zone. Take a few low-multiplier rolls to reposition, then press when you're approaching a cluster of scoring tiles again.
Keep the bigger picture in mind while you grind
Pom Pom Picnic is great for padding your dice total, but it's also a clean setup for whatever's next—especially if you're thinking about teaming up and planning your timing around partner activities. If you want to line up your resources and avoid scrambling later, it's worth keeping an eye on options like a Monopoly Go Partners Event for sale while you're cashing in milestones and deciding how hard you're going to push this weekend.
